How to run Visual Paradigm in Polish?
If your first language is Polish, you might find it more convenient to use a Polish User Interface instead of English which is in default. So that, you can understand the commands more easily and to perform the desired actions faster. Actually, Visual Paradigm supports the capability to allow users to switch to other languages where Polish is one of them. In the following, we will show you the way to switch your User Interface into Polish. Please follow the simple steps below.
- Select Windows > Application Options in the toolbar.
- In Application Options window, select General > Appearance.
- In the Installed User Language field, check Polish in the Use column.
- Click OK.
- Restart Visual Paradigm again.
Leave a Reply
