List out diagram/model’s comment
Doc. Composer can let you output every details of your models and diagrams in fully customizable way. In this article you will learn how to create custom template to output the comments of diagrams or model elements in a project.
Let’s start!
- Go to Tools > Doc. Composer > Manage Template XMLs.
- Switch the template category to General.
- Right click on any template in the list and select Duplicate from popup menu.
- Name the template as General/Comments, and select Table as template icon.
- Replace the template with following content.
<?xml version="1.0" encoding="UTF-8"?> <AnyBaseInitiationBlock> <Property anchorMark="true" property="name" style="@heading+"/> <ParagraphBreak/> <HasValueChecker property="comments"> <Text style="@heading+">Comments</Text> <TableBlock colWidths="20, 40, 15, 25" tableStyle="Summaries"> <TableRow> <TableCell><Text>Name</Text></TableCell> <TableCell><Text>Details</Text></TableCell> <TableCell><Text>Author</Text></TableCell> <TableCell><Text>Date/Time</Text></TableCell> </TableRow> <ForEach property="comments"> <TableRow> <TableCell> <Property property="name"/> </TableCell> <TableCell> <Property property="description"/> </TableCell> <TableCell> <Property property="author"/> </TableCell> <TableCell> <Property property="dateTime"/> </TableCell> </TableRow> </ForEach> </TableBlock> </HasValueChecker> </AnyBaseInitiationBlock> - Press Save button to confirm the change and close the Manage Template XML dialog.
- Go to Tools > Doc. Composer.
- Select Build Doc. from Scratch.
- Select the diagram or model you would like to output its comments.
- Right click on the Basic template and select Duplicate from popup menu.
- Name the template as Comments.
- Change the inline call to General/Comments.
- Press Save button to confirm the change, then close the template editor dialog.
- Drag out the Comments template into document editor.
Now the comments of the selected subject will be listed in a table.
Explanation of the Template
The reason why we create a Comments template under General category is to make it become a reusable component. This allow other elements reference to this template for outputting its comment, without writing the same template over and over on individual elements.
The template start with AnyBaseInitiationBlock which allow to be reuse by both diagrams and model elements.
Next we printout the name of the name of diagram or model element that the template works apply to in heading style.
After that we check did the subject contain comments.
If the subject contain comments then we print out the section title of the comment, and start print the table header.
<TableRow>
</TableRow>
Next we walk through the comment one by one to print out its details.
<TableRow>
<TableCell>
</TableCell>
<TableCell>
</TableCell>
<TableCell>
</TableCell>
<TableCell>
</TableCell>
</TableRow>
</ForEach>
Once this template is ready, we can then create comment template under individual diagram/model element, which call the General/Comments template for render of data.
<Inline template="General/Comments"/>
You can also call this template using Fill-in doc approach by specify the diagram/model level template.
${DIAGRAM, “DiagramComment”, “BPD”,Any, “Comments”}
${ELEMENT, “ClassComment”, “Class”,Any, “Comments”}
Related Know-how |
Related Link |
Leave a Reply
