| Since version 14.0 ArchiMetric had been replaced by Visual Paradigm Enterprise. |
ArchiMetric (former Visual Paradigm Enterprise Edition) is an all-in-one software and system development tool for end-to-end information technology system modeling. ArchiMetric comes with all the essential tools you need for Enterprise Architecture, such as ArchiMate, Zachman Framework, Business Process Model and Notation (BPMN), UML and more…. Similar to Visual Paradigm the ArchiMetric also support integrate with various IDE and allow you to perform requirement capturing, analysis and design as well as development within a single environment. But since the IDE integration is not the primary goal for enterprise architecture modeling users, the IDE integration menu is somehow a little bit hidden. To perform IDE Integration with ArchiMetric:
- Go to Window > Application Options.
Open Application Options
- Select General > Environment and turn on Advanced UI mode.
Turn on Advanced UI mode
- Press OK to confirm the change and close the Application Options dialog.
- Restart your ArchiMetric.
- After that you will find the IDE Integration menu under Window > Integration > IDE Integration.
IDE Integration menu become available after restart
Leave a Reply
