TP0001 – Cannot found project.xml in template
This problem is caused by user trying to create project using the template saved in user’s team repository. Unfortunately the key content cannot be found in the downloaded template. Possible reason is the template is uploaded in zip format but not create with correct structure.
User Action
User should contact administrator download the problematic template from repository. If it is a zip format template then please make sure the project.xml is located in the root of the zip. Once the structure being fixed then please remove the problematic template from repository and upload the fixed one for user.
See Also
How to Create Your Own Project Templates
Trying to import project to repository but being complain project already exist
Leave a Reply
