Solution to the Failure of Commiting/ Updating Project with SVN on Window 7 and Window 2008 Server [Obsolete]
| Team collaboration development on SVN had been discontinued starting from Visual Paradigm version 13.0 |
Since the file system of Window 7 and Window 2008 Server has been changed recently, thereby, you may encounter difficulties of committing or updating your project with SVN. What you can resolve the problem directly is to disable indexing. In this page, you can learn how to disable indexing when you fail to commit or update project with SVN on Window 7 and Window 2008 Server.
When you see the following pop-up dialog box during committing or updating your project with SVN, it means you fail to commit or update it.
Simultaneously, the log file shows the detected error as below:
- You can resolve the problem through control panel. Select Start menu > Control Panel > Administrative Tools > Services. In Services dialog box, right click on Windows Search and select Propertiesfrom the pop-up menu.
- When Windows Search Properties (Local Computer) dialog box pops out, select Disabled from the drop-down menu of Startup type and then click Stop button. Click OKbutton to confirm.
- As a result, the problem is fixed. You can try to commit or update your project again.
Leave a Reply
