Project Stereotypes being mess up by team!
There are lots of similar stereotypes being created in our team collaboration project. How can we avoid this problem? In Visual Paradigm you can grant edit stereotype permission to specific user/group, or allow particular user/group to edit the stereotype just on specified projects. In this article we will teach you how to configure your repository to achieve this.
The first step we need to do is to turn off the edit stereotype permission on the users.
  1. Login to server as Admin user, or as user who got Update Member permission.
    Login to server as Admin or user with Update Member permission
  2. Go to Member tab.
    Select Members tab
    Select Members tab
  3. Mouse over the member and press Edit.
    Edit member
    Edit member
  4. Switch to Permissions tab.
    Switch to Permission tab
  5. Change Stereotype (Project-based) permission to Deny.
    Set Stereotype permission to Deny
  6. Press Save button to confirm the change.
    Save permission change
  7. Repeat step 3 – 6 for all members (except the one who granted edit stereotype permission).
After apply this change all users (except the one still got stereotype permission) will not allow to create or define stereotypes. If you want to allow specific user override this on particular project:
  1. Login to server as Admin user, or as user who got Update Project permission.
  2. Go to Project tab.
    Select Projects tab
    Select Projects tab
  3. Mouse over on the project and press Edit.
    Edit Project
    Edit Project
  4. Switch to Members tab.
    Switch to project member tab
  5. Mouse over the member you would like to grant him stereotype permission and press Advanced Permission.
    Select Advanced Permission on member
  6. Select Stereotype (Project-based) permission and then close the dialog.
    Override stereotype permission on project level
  7. Press Save button to confirm the change.
    Save project change
    Save project change
After that the selected user will allow to modify the stereotypes on this project.
*All change of permissions will become effective after end user re-login the Teamwork Client in their VP application.
Related Know-how
Related Link
Leave a Reply
Want to join the discussion?
Feel free to contribute!
Leave a Reply
