How to Configure the Visual Properties of an Animation?
How to Configure the Visual Properties of an Animation?To animate a workflow in business process diagram enables you or your stakeholders to figure out a path easier. This is particularly useful when there are many possible paths in a business process.
During an animation, flow objects being reached by a token that controls the animation flow would be painted in purple. If you find the color not clear enough, or if you simply dislike purple :-), read this article to see how to change to another color.
  1. In the Animation Panel, click on the Options button next to the slider of animation.
    Opening the Options window
  2. In the Animation Options window, open the Advanced tab.
    The Animation Options window
  3. There you can change the line and fill color from purple to any other color. You can also configure the color of token (by editing Ball color), the speed of animation, etc.
    Editing the color options
  4. Click OK to confirm. When you play the animation again, you will see the new color applied.
    New color applied in animation
Related Know-how
Related Links
  1. Dominique Vauquier says:
    Animation as a capability is very useful to help you detect inconsistencies or lacks in your process design. For instance, in complex dynamics, it points out the interlock that an addition of gateways may provoke. So, it contributes to the quality review of the process.
Leave a Reply
Want to join the discussion?
Feel free to contribute!
Leave a Reply
