Create an Implementation Plan Diagram Using Open API
Implementation Plan is a project management tool that shows how a software project will evolve at a high level. This article will show you how to create an Implementation Plan Diagram using Open API.
The Implementation Plan Diagram will be created by the plugin.
Create Blank Implementation Plan Diagram
First, create a blank implementation plan diagram using the method Diagrammanager.createDiagram().
//Create Blank Diagram DiagramManager diagramManager = ApplicationManager.instance().getDiagramManager(); IArchitectureRoadmapUIModel implementationDiagram = (IArchitectureRoadmapUIModel) diagramManager.createDiagram(IDiagramTypeConstants.DIAGRAM_TYPE_ARCHITECTURE_ROADMAP); implementationDiagram.setName("Sample Implementation Plan Diagram");
Create Diagram Model
Unlike other charts and diagrams, a implementation charts’ elements are automatically rendered by the model, which is IArchitectureRoadmapModel. The model can be created using method IModelElementFactory.instance().createArchitectureRoadmapModel(). You will also have to set the widths of the time frames and the Lane using IArchitectureRoadmapModel. setTimeFrameWidth() and IArchitectureRoadmapModel. setLaneHeaderWidth() respectively.
//Create model IArchitectureRoadmapModel implementation = IModelElementFactory.instance().createArchitectureRoadmapModel(); implementationDiagram.setArchitectureRoadmapModelAddress(implementation.getAddress()); //Set the width for every time frame implementation.setTimeFrameWidth(75); //Set the length for every lane implementation.setLaneHeaderWidth(200);
Create Time Frames
Once the models are created, time frames can then be created from IModelElementactory.
//Create time frames IArchitectureRoadmapTimeFrame jan1 = IModelElementFactory.instance().createArchitectureRoadmapTimeFrame(); jan1.setName("Jan-01"); implementation.addTimeFrame(jan1);
You can try using this method to create more time frames.
Create Lanes
Lanes can also be created from IModelElementactory when the model is created.
//Create lanes IArchitectureRoadmapLane brmsBuild = IModelElementFactory.instance().createArchitectureRoadmapLane(); brmsBuild.setName("BRMSBuild"); //Specify the lane's color (and the corresponding bars) in RGB value brmsBuild.setColor(Color.BLUE.getRGB()); //Add the lane to the diagram implementation.addLane(brmsBuild);
It is now your turn to create more lanes.
Create Bars (Activities)
When both time frames and lanes are created, we can then create bars using IArchitectureRoadmapLane.createArchitectureRoadmapBar(). When after indicating the start and end time, and index, the bar can then be added to the Lane by the method IArchitectureRoadmapLane.addBar(). Please be noted that the start and end time pixels are calculated starting from the zero time frame.
//Create Bars IArchitectureRoadmapBar analysis = brmsBuild.createArchitectureRoadmapBar(); analysis.setName("Analysis"); //Specify the start time analysis.setStartTime(0); //Specify the end time analysis.setEndTime(100); //Index = n -> the bar is sitting on row (n+1) on the lane analysis.setIndex(0); //Add the bar to the lane brmsBuild.addBar(analysis);
You can use the same method to create more bars on the diagram.
Show Up Diagram
Finally show up the diagram.
//Show up the diagram diagramManager.openDiagram(implementationDiagram);
Sample Plugin
The sample plugin demonstrate how to create Implementation Plan Diagram using Open API. After you deploy the plugin into Visual Paradigm you can then click the plugin button in the application toolbar to trigger it.
Download Sample Plugin
You can click here to download the sample plugin.
Related Know-how |
Related Link |
Leave a Reply
