Visual Paradigm 17.2 Cannot Perform Code Synchronization with Eclipse 2024-09 Integration
You may receive complain that your Eclipse project is not a Java project when perform code generation/reverse engineering with Eclipse 2024-09 integration.
To solve this problem:
- Shutdown your Eclipse.
- Run the Visual Paradigm Update under the bin folder of Visual Paradigm installation directory.
- Press the Update to latest patch button right after launching Visual Paradigm Update.
- Follow the wizard to update the software to latest patch build (20240920bh or later).
- Open Command Prompt and navigate to Eclipse installation directory.
- Execute eclipse –clean command.
After that the code synchronization problem will be fixed. For next time you can launch Eclipse in normal way without the –clean command.
Related Know-how |
Related Link |
Leave a Reply
