Create Generalization Set using Open API
tomcat-thumbThe generalization set defines a set of generalization relationship that describe how the superclass may be divided by a set of subclasses. The generalization defined in the set can group together in diagram for better presentation of the model. The generalization set can defined via the GUI on diagram or using Open API. In this article you will learn how to create generalization set using Open API in Visual Paradigm.
Create Classes Diagram and Classes
Let’s start by create the class diagram and classes. We can use the DiagramManager.createDiagram() method to create the diagram.
// Create Class Diagram
DiagramManager diagramManager = ApplicationManager.instance().getDiagramManager();
IClassDiagramUIModel diagram = (IClassDiagramUIModel) diagramManager.createDiagram(IDiagramTypeConstants.DIAGRAM_TYPE_CLASS_DIAGRAM);
Once the diagram is created we then create class models and its view on diagram.
// Create Super Class model and shape
IClass superClass = IModelElementFactory.instance().createClass();
superClass.setName("SuperClass");
IClassUIModel superClassShape = (IClassUIModel) diagramManager.createDiagramElement(diagram, superClass);
superClassShape.setBounds(150, 50, 80, 40);
superClassShape.setRequestResetCaption(true);
Let’s try it yourself to create the sub-classes.
Once the classes are created we can then create the generalization model and connector.
// Create generalization model and connector between super class and sub-classes
IGeneralization generalization1 = IModelElementFactory.instance().createGeneralization();
generalization1.setFrom(superClass);
generalization1.setTo(subClass1);
IGeneralizationUIModel generalization1Shape = (IGeneralizationUIModel) diagramManager.createConnector(
                        diagram, generalization1, superClassShape, subClass1Shape,
                        new Point[] {	new Point(190, 90),
                                new Point(190, 120),
                                new Point(90, 120),
                                new Point(90, 150)});
generalization1Shape.setRequestResetCaption(true);
Now try it yourself to create the other generalization between superclass and subclass 2.
Now we can create generalization set model and associate it with the generalizations we created.
// Create generalization set model
IGeneralizationSet generalizationSet = IModelElementFactory.instance().createGeneralizationSet();
// Add generalizations to generalization set
generalizationSet.addGeneralization(generalization1);
generalizationSet.addGeneralization(generalization2);
// Create generalization UI model
IGeneralizationSetUIModel generalizationSetUI = (IGeneralizationSetUIModel) diagramManager.createDiagramElement(diagram, generalizationSet);
// Set notation for generalization set to common arrow head
generalizationSetUI.setNotation(IClassDiagramUIModel.GENERALIZATION_SET_NOTATION_COMMON_GENERALIZATION_ARROWHEAD);
Show up the diagram
Finally we can show up the diagram.
// Show up the diagram
diagramManager.openDiagram(diagram);
Sample Plugin
The sample plugin attached in this article demonstrate how to create generalizations with generalization set. After you deploy the plugin into Visual Paradigm you can then click the plugin button in the application toolbar to trigger it.
Trigger Sample Plugin
Download Sample Plugin
You can click this link to download the sample plugin.
Related Know-how
Related Link
Leave a Reply
Want to join the discussion?
Feel free to contribute!
Leave a Reply
